03-21-2012 05:21 PM
Hi Tommy,
Is it a constant value at 128 or 384? If so, my best guess would still be the ground current loop.
03-22-2012 05:06 AM
Hi Josh
I had put a Configure Power supply Parameters.vi in the while loop so I could adjust the voltage, I added after Error Query.vi When I moved it to before Error Query.vi, it worked as it should![]()
03-23-2012 09:25 AM
Hi Tommy,
Good fix! Thanks for letting us know not only that the issue is solved but also how you solved it.
04-28-2014 06:01 PM
Does someone have this vi in this form? I would like to know what the front panel looks like. Thanks. Jeff
04-28-2014 06:41 PM
04-29-2014 01:03 AM
Hi Jeff
See attached![]()
04-29-2014 11:58 AM
Yes, I installed the drivers. No, NONE of them work. YES, I am communicating with the instrument. In this image, is this .vi available? What would really, really, really be handy, and is rarely done, is a sample .vi which sets a voltage, reads a current, or vice versa. Very simple. Does anyone have this ? Does National Instruments have this? What is the .vi shown in this image? Thanks. Jeff http://forums.ni.com/ni/attachments/ni/140/52437/3/Array%203646A%20functioning.png
04-29-2014 12:16 PM
04-29-2014 01:28 PM
Hi Jeff
Yes, I installed the drivers. No, NONE of them work. YES, I am communicating with the instrument. In this image, is this .vi available? This is the sample shown in the 'Start Using Instrument Driver' image above. What would really, really, really be handy, and is rarely done, is a sample .vi which sets a voltage, reads a current, or vice versa. Very simple. Does anyone have this ? Does National Instruments have this? What is the .vi shown in this image? This is the same, please read my answer from 03-22-2012 05:06 AM Thanks. Jeff http://forums.ni.com/ni/attachments/ni/140/52437/3/Array%203646A%20functioning.png
01-21-2016 04:11 PM
Hello everyone!
I ve got problem with comunication. Is it possible to communicate without 3311 adapter? I ve got just device and RS232->USB cable. Examples from http://sine.ni.com dosn't work and I do not know what I should change.
Greetings!
