Auto Initialize DMM
Does anyone know how to initialize PXI DMM without opening DMM soft front panel when I start PC?
Adam
(4,118 Views)
You could write a program with just the initialize function in it and place the program in your startup folder. Not sure why you would need to initialize on startup though. Do you have an application that uses it and doesn't it initialize the instrument at the beginning?
(4,102 Views)
Accepted by topic author Meng-Shiang.Lin
Hi, Adam
Please add the ini files for initializing the instrument when OS starting up. While OS loading the ini files, here sometimes comes an error message. It occurs to OS loading the ini files before the environment being ready. Therefore, adding a waiting time, ex. 10s, can solve this error.
Thanks.
NITW
AAron
(4,088 Views)
