Blue Screen (BSOD) while communicating with GPIB Instrument
About the 'Wait (ms)' vs. 'Wait Until Next ms Multiple' discussion:
Could it be better to use the 'Time Delay' Express-VI located in the same pallette as the other two VIs?
cu
Message 11 of 17
(3,561 Views)
Quaker,
With GPIB ( or other parrallel busses) I tend to prefer Async VISA calls.  It is a holdover from my LabVIEW 7.0 days and relates to some of the "interesting" behaviors that I mentionedin passing.  The later versions on NI software (VISA and LabVIEW) seem to make the sync/Async choice a matter of coding style for MOST applications.  Of course, read about and learn the differences!  But I will make no firm recomendation.
As to the timing,  Frankly- I use this VI exclusivley and avoid Wait(ms).vi.  It has some disadvantages if code optomization is a high priority but, it will predict a Windows mSec clock roll over and return at the correct time (according to the system timer)
Message 12 of 17
(3,549 Views)
Jeff,
can you convert the VI to LabVIEW V8.5 please?
Thank you  Smiley Happy
Message 13 of 17
(3,544 Views)
So it seems like this thread has gone off on a tangent, but was anything ever found regarding the original blue screen? Was a crash dump ever generated that could be sent in?
-Jason S.
Message 14 of 17
(3,524 Views)
My new findings:
1) As described in the first message I'am sending different messages to the instrument (totally 4 of them). Now I tried the same experiment with fewer messages and observed, that there is no problem if i send only the "_PCS4\sREADING?\n" message. But if I send the "_PCS4\sREADING?\n" and the "_PCS4\sERR?\n" messages consecutively the computer will crash. Afterwards I tried only to send the "_PCS4\sERR?\n" only and the computer crashed too! So it seems to be a problem related to this message.
2) I tried the same program using the VIs from NI-488. The result is the same as with the VISA version.
3) I tried different types of waiting (using 'Wait Until Next ms Multiple' and/or using 'Wait(ms)'). The computer crashes anyway.
Jason,
there are some older Mini Dump Files created by other Blue Screens ("DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)"). The latest one is from the 23.7.2009 (then the problem didn't exist such intensely). I analyzed them with the Kernel Debugger (kd.exe) from Microsoft already. All these Files are indicating problems with the nimdsk.dll file. Which LabVIEW component is using this dll?
Unfortunately I couldn't update NI-VISA etc. so far because the computer is often used by other people. I will do it as soon as i can. Also I will study the documentation about the instrument in more detail. Perhaps I can find any specialities with the "_PCS4\sERR?\n" command.
Is there a PCI-GPIB card specific driver which I can update too?
Have a nice weekend.
Message 15 of 17
(3,517 Views)
Accepted by Quaker
I have some good news Smiley Happy
I installed NI-VISA V4.6 today, but this didn't solve my problem. But after I installed NI-488.2 V2.7.1 (the latest version too) my small application worked perfectly. I tried it only about 3 minutes, but the computer didn't crash.
What happened:
I observed that after the reboot (after the NI-488.2 installation) windows installed the PCI-GPIB card again. So I checked the new driver version in the device manager of windows. There I discovered that a new driver for the card itself was installed (V2.7.0.49152, Date 28.1.2009, WHQL certified). The previous faulty driver was V2.5.2., 1.1.2007.
Conclusion: I think the new driver for the PCI-GPIB card solved my problem.
I will do some more (longer) tests and let you know if the problem is solved definitifely...
Bye
Message 16 of 17
(3,455 Views)
After some additional tests, the problem seems to be fixed by installation of the latest NI-488.2 driver (see post above).
Thank you all for your help.
Message 17 of 17
(3,395 Views)
