Hello, first i wan't to apologize because of my english is not very good. I've got an VI that take the signal of 6 "distance sensors" with an NI USB 6008, everithing wired, and the data of the 6 sensors are been taked by the program continuously; I would like to change the data acquisition device and the cables connectig each sensor to a bluetooth device. It's able to receive de data from the six sensors at once? Or if it can't be at once then with speed enough like the 6008 does (taken about 20 samples per second from each sensor)? All this data will go to a Toshiba laptop with the bluetooth that it bring from the factory ( i give that because i don´t know if it can be relevant).
Thank you very much.
