CHROMA 62012p power supply
I am trying to communicate with CHROMA 62012P power supply using labview 14 32-bit through USB. It is always throwing error. When I am passing IDN command from NI-MAX it detects the instrument properly.
I tried the same vi using labview 8.5 version and it works fine and I am able to get my result.
What could be the issue causing this error?
Message 1 of 1
(2,773 Views)
