agilent 33220A pulse wave problem (labview beginner)
I want to construct a pulse wave using 33220A as follows conditions.
sweep pulse wave 0V to 4V
edge time 8ns
width and frequency, it does not matter but the shorter it is the better.
I used Agilent 33XXX series example - standard wave form example to find the approximate pulse wave,
but this method was not able to set the edge time.
Conversely, if you try to apply pulse wave vi file (instrument I/O - driver - 33XXX - configure - pulse)  to example file,
it can only set period, width, and edge time in the pulse vi file. I could not find the voltage level setting.
I want to know if I can construct a pulse wave with the following conditions using the labview 33220a example, and I want to know where to start.
Message 1 of 1
(2,509 Views)
