Keithely 2636B labview driver not supported?
Hi I'm Lee.
Recent I am trying to make simple IV measurement program using Labview 2016.
But I couldn't find any Labview drivers for K2623B or K26xx on Ni and Keithley web page.
Someone help me to solve this problem.
I have experienced the K24xx labview.  but I heard that it is totally different the labview in K26xx.
Please anyone attaching the example vi. (apply voltage, read current on channel A and B etc.)
Thanks.
(4,238 Views)
The Keithley 2636B has a Keithley 2400 mode that allows for SCPI programming.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,221 Views)
The 2636B uses the 26xx LabVIEW driver that is available from the Tektronix (owners or Keithley) web page - https://www.tek.com/source-measure-units/2635-software/keithley-series-2600-2600a-2600b-native-labvi...
You need to create an account to download it.  I use and its fully functional.  That said, it could use some more advanced exxamples.
As for using the 24xx driver with a 26xx SMU.  It does work, there's an emulation mode you can set the 26xx into to accept the 24xx SCPI commands. If you have a whole pile of 24xx code already written then its a valid option.
But, the emulation mode doesn't offer support for the newer features of the 26xx including the possibility that your 26xx has 2 SMUs.  There's no way to setup or use the second SMU with 24xx SCPI commands.
(4,208 Views)
