COM Port access via DLL inside Labview is not possible
Hello.
I've written my own DLL in C# for communication during production process.
But always if I want Labview to use this DLL the communication fails at the first step: Opening the com port.
So I removed all of my code and made only a small DLL which opens/closes the com port.
When I execute the command line tool which uses exactly the same dll as Labview, COM port opening is possible.
The com-port can be chosen by adding a Parameter like "COM1" to the .exe file.
The function inside the dll must be called like: communication.open("COM1") and returns a "true" in case of error.
It would be very nice if somebody could help me and find the error.
Best regards
chosn
(5,085 Views)
LabVIEW has built-in serial port communication ability  Instrument IO --> Serial. Why are you writing your own DLL to do this?
(5,077 Views)
Hi, because the functions in the DLL should be used later on different systems (with and without labview).
But normally should be a COM-Port access inside a DLL be possible in Labview?
Regards
(5,068 Views)
Accepted by jfisch
Hi again.
I changed my dll to output the Exception of my try-catch function during opening the port to a string.
System.Security.SecurityException: Fehler bei der Anforderung des Berechtigungstyps "System.Security.Permissions.SecurityPermission, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089".
   bei System.Security.CodeAccessSecurityEngine.Check(Object demand, StackCrawlMark& stackMark, Boolean isPermSet)
   bei System.Security.CodeAccessPermission.Demand()
   bei System.IO.Ports.SerialPort.Open()
   bei OpenComPortTest.communication.open(String port_selection)
Die Aktion, bei der ein Fehler aufgetreten ist:
Demand
Der Typ der ersten Berechtigung, bei der ein Fehler aufgetreten ist:
Die Zone der Assembly, bei der ein Fehler aufgetreten ist:
Intranet
The problem was, that the dll has been on a mapped Network drive.
After moving it to a local drive, it works.
Regards
chosn
(5,060 Views)
@jfisch wrote:
Hi again.
This is a .NET security "feature".
(5,049 Views)
Dear chosn,
I want to create a Serial port dll using visual C++,
and i want to use that dll in Lab view application.
Can you please help me to create Serial port dl..
thank you
Sunil
(4,873 Views)
