COM Ports do not show under serial and parallel in NI Max
Yes I did but as soon as I press Run it turns grey and everything returns to default values baudrate, board type etc.
I tested with Hyperterminal just a simple example of sending H to turn on LED 13 and L to turn it off and worked as expected.
Message 11 of 13
(2,152 Views)
I don't have the arduino toolkit so I can't reproduce this, sorry.
Message 12 of 13
(2,148 Views)
The second part of the errormsg read:
and that the arduino is flashed with the correct firmware
Which firmware do you have?
greetings from the Netherlands
Message 13 of 13
(2,137 Views)
