COM port time out, but can read back data from MAX
When short RX and RX directly, COM port can feedback data on MAX test panel, but always display "time out" error. What's the possible reason? Thanks.
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
(4,831 Views)
Accepted by colinzhang
Hi Colin,
When you read back the data, there is a parameter called "Bytes to read" you need to key in, the default value is 1024, in this case, it will keep waiting for 1024 bytes until the timeout occur.
I found a good article talking about this and you can change the bytes to read in the LabVIEW environment or MAX test panel.
http://digital.ni.com/public.nsf/allkb/874B379E24C0A0D686256FCF007A6EA0
Do let me know after you try it out, thanks.
KwokHow
AE NI Singapore
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(4,807 Views)
If you leave the default port settings, then you can use a termination character to stop the read.  By default, it is 0xA (line feed).  So if you addend a line feed to your sent data, then it will work much better.
(4,797 Views)
Hi Asean,
Thanks your reply, this issue has been resolved. You are right.
Colin Zhang
(4,745 Views)
Thanks for your reply, your info is useful as well.
Colin Zhang
(4,742 Views)
