Can I connect PCI 8431/8 Port RS 422 Card using cable part no. 192061-02 ( SHC68-68-EPM Shielded cable)
I have ordered NI PCI 8431 / 8 Port  RS 422 card. It has 68 pin connecctor. The card comes along with cable which 68 pin to 8 DB 9 connector. Instead of using this cable, can i use NI cable part no. 192061-02 to my test system. This makes my connection very simple.
Please calrify whether this will work or  not.
Regards
Bose
(4,400 Views)
After looking at the pinout for the cable you mentioned (192061-02), I see that the cable is not compatible with carrying signals from the PCI-8431/8.  The cable is mostly a straight through cable, but it is not capable of transmitting all of the required serial signals.
I hope this helps,
Steven T.
(4,377 Views)
