Can I convert USB to RS232 by using USB-GPIB cable an GPIB-RS232 converter?
Hi All,
         As the title,  due to some special reasons, I am trying to convert the USB interface to RS232 in that way, could that be work?
         one more question, Can I set serial mode, such as S mode, C  mode etc in MAX
         Thanks a lot
(3,751 Views)
For a few dollars you have a usb to serial converter so why bother to go via gpib?
greetings from the Netherlands
(3,748 Views)
yes, you are right , but for some special reasons, I have to trying that. can anyone guide me if it will works?
(3,745 Views)
theoretically speaking it works ,however it's not worthy of that,you may have try.
(3,724 Views)
