I want to trigger a keithley485 picoampere, conected to labview 6 through a USB/GPIB cable (82357B-AGILENT), with a usb signal coming from an spectrometer
I´m  new and it cost really time. I found the drivers for keithley here but I could only se version6 and I don´t find them complete. The thing is I can already comunicate with the instrument from Agilent interactive I/O and conetion expert. I even created there an alias for the visa, but I don´t know how to go on. I do not now how to iniciallizate and construct the whole program. I have though an idea, and I could also buy version 8 if its really necesary. but i need some subIV like those for the HP34410 that already exist in Labview. thanks in advance for your suggestions.
(4,111 Views)
Hi Pirri,
you have two options controlling your Keithley 485:
1. PnP Instrument Driver http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=345, only available for  LabVIEW 7.0+
2. Program the driver VIs yourself. Take a look at the GPIB examples. Command Reference and programming model for the 485 can be found at:  http://www.keithley.com/search?searchType=general&SearchableText=4853
Upgrade LabVIEW: http://ohm.ni.com/advisors/ua
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(4,081 Views)
naja, das problem is both existing drivers are not so consistent (not to say they are a crap). there is no inicialization and I need a visa path because I use a USB. also the NI visa should be more than 3.5 for beeing compatible with USB. I have desisted but thank you
(3,997 Views)
Since the Keithley driver was written by Keithley, you should send your concerns about it to Keithley. You can also modify the driver yourself. Replace the GPIB Read/Write functions with VISA Read/Write and wire appropriately. More tedious than difficult.
(3,995 Views)
