Can I use Labview8.2 with GPIB interface to read from data file to control DC power supply Agilent 6674A output waveform?
I am currently working on the project to control Agilent 6674A (DC power supply up to 60V VDC output).  If I have the data file (Voltage vs Time), Can Labview using the GPIB interface to read from the data file , so the 6674A can output whatever the wave form from the data file ?
The output from Agilent 6674A will be capture by Data Acquisition Card or Scope .
(3,451 Views)
Sure you can. What specifically do you need help with? You've got a driver available to control the instrument and you can easily read the file. You could use something like the Read From Spreadsheet File. You would have a 2D array with voltages in one column and the times in the other.
(3,448 Views)
Thanks for your reply , I am very new to Labview . I need help to build the GPIB VI to read the data file . Am I correct ?
(3,445 Views)
Depending on the format of the file, you have built-in functions to do the read. A text file with comma or tab separated data is the simplest. The function I named is designed for that. If you get stuck somehow with the read, post an example of the data file.
For learning LabVIEW, you have some tutorials to start with.
(3,441 Views)
