04-03-2024 12:45 AM - edited 04-03-2024 12:48 AM
I want to connect GPIB interface over USB connection. I have choosed GPIB interface on the oscilloscope but I see only USB connection on the NI Max program. Can I use USB hardware interface as GPIB interface?
If this is possible what should I do?
All information in the below.
SETUP
- Keysight InfiniiVision DSOX3024T oscilloscope
- Keysight DSOXGPIB GPIB Module
- USB cable
- NI MAX (NI VISA + NI-488.2 driver)
- I have chosed GPIB interface on the oscilloscope.
Solved! Go to Solution.
04-03-2024
02:23 AM
- last edited on
07-09-2026
11:57 AM
by
Content Cleaner
You'll need a USB-GPIB adapter for that such as: https://www.ni.com/en/shop/hardware/gpib/model-gpib-usb-hs-
04-03-2024 07:15 AM
Either an NI variety USB to GPIB as rolfk mentioned or a lower cost option like the Prologix GPIB-USB Controller and use the notes here that I have provided.
