Can I use a sub cam on CRio 9049?
hi all,
I'd like to get continuous image from USB cam(intel REALSENSE) that is connected to the USB port on CRio 9049.
But I don't know where I can get image (I/O node, or something).
I've seen previous forum(https://forums.ni.com/t5/Machine-Vision/USB-webcam-on-a-cRIO/td-p/3327542), but I cannot find webcamera support of crio 9049.
I'm new to FPGA, so if you need more information, please tell me.
Thank you for your attention.
(1,579 Views)
Accepted by cleska
I suppose you'll be able to get image on RT target not on FPGA target. Please check it. I don't think there is I/O node for camera on cRIO FPGA target.
(1,528 Views)
Hi, vardanium.
Thank you for your reply.
I understood where I should grab the image.
Now, I can use the usb port on cRio, and run host program on cRio.
Again, thank you for your kindness!
Best regard,
CleSka.
(1,523 Views)
