Can not open a gpib interface instructment session by VISA at VxWorks
I have a VXIpc770 (runs VxWroks 5.5) with GPIB interface.
After booting, i load below modules:
nivxi.o, vxiedit.o, resman.o, victext.o, nigpib.o, ibic488.o, visa.o
it works if use ibic function to control my GPIB instructment. below is the code: (it is a example code on the user manual )
int getInst()
    char buf[1000];
    printf("find board\n");
    int board = ibfind("gpib0");
    if( board == -1 ) {
        printf("fail to open board\n");
        return -1;
    printf("ibsic, status=%x\n", ibsic(board));
    printf("send command '@!', status=%x\n", ibcmd(board, (void*)"@!", 2));
    printf("send command '\\04', stauts=%x\n", ibcmd(board, (void*)"\0A", 1));
    printf("write '*IDN?', status=%x\n", ibwrt(board, (void*)"*IDN?\n", 6));
    printf("send command ' A', status=%x\n", ibcmd(board, (void*)" A", 2));
    printf("read, status=%x\n", ibrd(board, buf, 1000));
    buf[ibcnt]=0;
    printf( "%s\n", buf );
    ibonl( board, 0);
but if i use VISA function. i don't work.
viOpen( &rm , "GPIB0::1::INSTR", 0, 0, &inst)
the error status is bfff0011 means no such instructment
(i can open other instructments such as "VXI0::24::INSTR" use by VISA)
how do i config the visa to make it works?
Message 1 of 8
(4,722 Views)
Hello Zodicx,
What versions of the GPIB and VISA drivers are you using?  Are you using the NI-488.2 DDK?
Have you been able to use VISA to open a serial port and communicate that way?  I would be curious about this because it would show if VISA is configured correctly on your system.
Steven T.
Message 2 of 8
(4,682 Views)
I don't know what version the GPIB and VISA drivers are. Can you tell me how to check it?
I can use viFindRsrc function to find below instructment:
ASRL1::INSTR
ASRL2::INSTR
VXI0::0::INSTR
VXI0::8::INSTR
VXI0::24::INSTR
and i can use viOpen to open ASRL1::INSTR and VXI0::8::INSTR etc.
i was follow VXI "Getting Started with Your VXIpc Embedded Controller for VxWorks" to load the nivxi.o and visa.o etc.
Message 3 of 8
(4,653 Views)
You can check the versions in the Measurement and Automation Explorer (MAX), by expanding the Software section of the tree on the left.
Gavin Fox
Systems Software
Message 4 of 8
(4,640 Views)
I check my gpib driver version is NI-488 for VXIpc for VxWorks, v2.2 and National Instruments NI-VISA(TM) Software for VxWorks. Version 2.5.1.
i do not have any ideal that have "Measurement and Automation Explorer" software in the "VxWorks".
Message 5 of 8
(4,632 Views)
Hi zodicx,
NI-VISA 2.5.1 did not support GPIB on VxWorks, although it supported other VxWorks 5.5 resources such as serial communication.
Gavin Fox
Systems Software
Message 6 of 8
(4,617 Views)
Ok.
Can you tell me what version of NI-VISA suport GPIB on VxWorks.
Thanks.
Message 7 of 8
(4,606 Views)
Accepted by zodicx
Hi zodicx,
There is no NI-VISA GPIB support for VxWorks.  Are you able to use GPIB directly?
Gavin Fox
Systems Software
Message 8 of 8
(4,595 Views)
