Can not set Voltage on a Keithley 2380-500-15
I have been trying to control a electronic load system from Keithley but am unable to set voltage manually or using py-visa.
Here is some code that just receives errors:
def set_voltage(user_input):
import visa
rm = visa.ResourceManager()
inputs = rm.list_resources()
usb_port=(inputs[0])
keith = rm.open_resource(usb_port)
print(keith.write("*VOLT " + str(user_input)))
set_voltage(1.0)
import visa
print(keith.write("SYST:ERR?"))
Both say status success but then an error appears above the screen.
(2,732 Views)
Please explain about setting voltage manually.
(2,714 Views)
My end goal is to create a program where I just type in the voltage and a function will set the voltage on the Keithley electric load system. In order to try and make the code for that I am trying find out the process the machine takes to set voltage by setting it manually (just pressing the buttons on the machine). I have read the users manual and am unable to remotely or manually set the voltage on the Keithley machine
(2,703 Views)
An IVI driver is available.
greetings from the Netherlands
(2,660 Views)
