Can query serial port with NI MAX, but doesn't work in Labview
I'm trying to control a Coherent Sapphire 488 with labview. It's connected via a serial to USB converter into the computer. I can communicate with a device using NI MAX, but when I try to run the vi (attached), it works for several queries, but evetually returns a null character, after which I can no longer communicate with the port. If I then go into the NI MAX interface, every time I try to read it gives the "VISA: (Hex 0xBFFF0015) Timeout expired before operation completed" error message.There are also several queriess from the instrument's manual that don't seem to work at all (with or without MAX) and always return a null character. Any help is appreciated. I'm certainly a novice with device communication. Thanks.
(5,713 Views)
Accepted by jwlarkin
Generally issue with termination character.
 And you are sending     \  and  r   and not CarriageReturn.
(5,703 Views)
Thanks a lot, man. Swapping \r for a carriage return constant seems to have worked.
(5,699 Views)
Is it \r\n?
(3,399 Views)
mikemai,
There's actually a constant in LabVIEW called "Carriage Return," or you can use \r
You can check out this document for more information: Difference Between Carriage Return, Line Feed and End of Line Characters
If you have additional questions I'd suggest making a new forum post, since this one is from 2012 and likely not monitored closely.
Francine P.
Applications Engineering
(3,388 Views)
