02-02-2006 02:11 PM
02-02-2006 02:29 PM
02-02-2006 02:42 PM
Before using Labview, I used a program called TestPoint. The program that was created using the other software controlled my setup, but it couldn't multi-task like Labview and it lacked other key features. With that being said, I'm sure I have the correct cables. I'm trying to control a motor along with some other functions. Here is what I'm dealing with:
http://www.a-m-c.com/download/datasheet/DR100EE30A40NAC.pdf
This device requires power in order to function, but when I turn it on I can no longer communicate with the serial port because it's busy with the driver. I need a lot of advice. Help!
02-02-2006 02:57 PM
According to AMC's documents, you need a straight through cable for this drive (not a null modem cable where pins 2 and 3 get swapped). Have you attempted communications with AMC's own program just to verify drive's port is not damaged? See:
http://www.a-m-c.com/content/support/digital/100series.html#rs232
Verify this first, If OK, then I suggest you power everything down and back up and try communications with Hyperterminal as the next step. Let us know how it goes.
02-03-2006 08:26 AM
02-03-2006 08:57 AM
02-03-2006 10:08 AM
02-03-2006 10:15 AM
02-03-2006 03:44 PM
02-03-2006 03:56 PM
JBadon:
I wish I had something concrete for you to pursue. All I can assume is that you have used ALL the SAME settings from your Testpoint program (COM port #, baud, parity, stop and data bits, handshaking, TERMINATION CHARACTER, etc) for your Hyperterminal setup and LV code. I capitalized termination character because Hyperterminal typically automatically adds a linefeed and/or carriage return to the end of the transmitted string. Please double check all the settings. Other than that, I am clueless right now ![]()
