Can't create .PNF file from .INF file
I tried,  but still there it is not working...!
Are there any settings I need to do in windows 7
Message 11 of 19
(3,173 Views)
Any thoughts..........!
Message 12 of 19
(3,158 Views)
I'm familiar with inf files, but what is the pnf file you are referring to?
Shane
Message 13 of 19
(3,144 Views)
Thanks for you reply..!
Can you pl take a look in the link below under section 2.2. Install the INF files and the USB device in 4th point.
There the point is mentioned; of generating the PNF from INF...
http://www.ni.com/white-paper/4478/en
Message 14 of 19
(3,137 Views)
Just to echo the concerns Dennis has had:  You're not looking to get any kind of useful information fromt his exercise any time soon, right?  I understand you're doing it as a learning process which is OK but if the reason is any other then you're probably going to waste a lot of your time.  Since YOUR time doesn't cost ME anything, I'll answer what I can.
I've never noticed a PNF file in my workings with USB.  Could be that the file is created somewhere deep inside th Windows folder......  When you attach your device after doing all the other steps, soes it get loaded as a VISA device?  Can you show the device in your device manager view on the PC so that we can see how it's being initialised?
Shane.
Message 15 of 19
(3,118 Views)
Hello Thank you...! Yes you are right..! The .PNG file is getting created; Now I have proceeded to next step;
 Test Communication with VISA Interactive Control
I don't see the device in the Measurement & Automation Explorer under  "Devices and Interfaces"
I'm I missing any settings ....????
Message 16 of 19
(3,110 Views)
Ah, HID, that's the bit I was missing.....
In windows 7 you CANNOT replace the system-default HID driver with any other (Ask Bill why).  My nuggets on HID communication with VISA will NOT work in Windows 7.....
Sorry.
Shane.
Message 17 of 19
(3,091 Views)
Hello Shane,
Yes you are right..! It is a drivers issue...!
I could solve the issue by updating the NI drivers; I could get the DVD form an NI Application engineer; but according to him we can also get them online....
Thanks..!
Message 18 of 19
(3,077 Views)
What? That's not actually what I said at all.
Either way I'm happy ou have a solution to your problem.  Whatever the solution may have been int he end.
Shane.
Message 19 of 19
(3,071 Views)
