Can't find GPIB instrument with Linux Labview
   I am trying to communicate with an Agilent 33250A Pulser via NI GPIB-ENET/100. When I use the GPIB explorer in Linux, I scan the local subnet for the device and it can not seem to find it. However, I can ping it and get a response.
   I also tried to just enter the IP in the GPIB explorer and then run  the NI-488.2 Troubleshooting Wizard. The first two stages pass but the "GPIB Interfaces Sequentially" test does not. Below is a copy of the NI I/O Trace capture:
> 1.  ibfind(GPIB0)
> Process ID: 0x0000117C         Thread ID: 0x004AFB30
> Start Time: 13:36:34.082       Call Duration 00:00:10.012
> ibsta: 0x8000       iberr: 0             ibcntl: -519700363(0xe1060075)
> 2.  ThreadIberr()
> Start Time: 13:36:44.094       Call Duration 00:00:00.000
> 3.  ThreadIbsta()
> 4.  ThreadIbcnt()
I have already been successful with this task in Windows Labview and can see the ENET and Instrument fine with MAX in Windows.
Any help would be great!
-Robert
(3,489 Views)
Hi Rwwt, you can ry the following links to check if it helps you discovering the device:
Using the GPIB-ENET/100 With Multiple Network Devices in Linux
Configuration of GPIB Devices in Linux
Eric NI
(3,473 Views)
