how i can read particular data(temperature) which is in second column in excel by giving particular data(time) of first column
problem no. 1
by giving simple time or date at input then i can get all data corresponding to that date or time in the format of array or in the format of chart or graph .
as like in excel data is in the format
12/6/2012   4:12:34 pm   456.6777
12/6/2012   4:13:34 pm   556.6777
i can give date 12/6/2012 in labview then i can read 456.6777 and 556.6777 in array or graph or chart.
problem no. 2
how i can put a external scroll for x -axis in waveform chart (absolte current time on x axis )to see previous data at the time of run time.
i don't want any running data on chart during holding scroll which happens with x axis scroll bar which is given in waveform chart by clicking right click .
(3,367 Views)
What does this have to do with Instrument Control. Please repost to the appropriate language board.
(3,364 Views)
problem no. 1 (for serial interfacing and Gpib interfacing ) temperature monitor of lakeshore 218
as i   give date 12/6/2012 in labview then i could  read 456.6777 and 556.6777 in array or graph or chart.
problem no. 2
(3,357 Views)
Your problem is that you still do not know how to post your question to the correct board.
(3,350 Views)
