Can't read each iteration value of for loop
Manisha,
How are you certain that your device is responding in 5 seconds?   How many bytes does it send?  There is a property node for the timeout.  Read that to check the value.
Look at the queue examples for some ideas about how to move data between parallel loops with queues.
Lynn
Message 11 of 15
(1,151 Views)
Well I can't view the .vi files at the moment as I don't have LabVIEW at home, but you do know when you connect an array to a for loop that when it automatically makes the bracketed box instead of the solid box that it is auto-indexing unless you change it back.  It seems you go the part about putting the code that you want to repeat for each reading inside the loop, but I just figured I'd point this as as in a case such as this if you want to run the loop once for each element in the array you don't have to wire anything to N as it will automatically execute until it runs out of elements in the array with autoindexing.  If you are converting the strings to numbers than you can actually use a single (for instance) convert decimal string to decimal) function and wire the entire array and the output will be an array of all the strings converted to decimal numbers in one swoop.  You could then just resize the indicator on the front panel to view all the elements if you wish and there is no further processing to do and be done with it.  Recording the readings could again be done as the whole array at one time (you can use the more complicated report functions if you want to do specific row and column placements, but I find basic appended log files to be the easiest for large amounts of data storage and then if necessary do post processing later), but again you could probably just write the %s strings directly.  If you are just wanting to log the data to a text file, then since most of the time this is saved as a numerical string anyway you could simply wire the entire array to some of the write to file routines especially if it is a basic tab delimited file and you are just appending data to the end of the file.
As far as the time-out problem, you can specify a different time-out time limit in several places.  You can specify it in the Measurement and Automation Explorer configuration or using the initial GPIB Configuration routines.  If you are using a VISA address I believe you can also go to the create property node right click menu option and in there I think is a time-out parameter.  The basic GPIB read/write functions I'm pretty sure have an optional timeout input.
It could be something as simple as leaving off some of the required command termination characters (usually the carriage return <cr> or "/r" and/or line-feed or "/n" <lf> characters) especially if you don't allow enough time for a command to be received and acknowledged before sending the next.  It could also be that you are making your command requests too rapidly with not enough pause and the device is not ready for the next sequence and so it misses the command and so goes into waiting and the computer sits waiting for a response (as the acknowledge from the just completed command can often be mistaken for acceptance of the missed one).  Sometimes the device misses the command, but has a command queue capability and will sometimes after a delay suddenly see the waiting command and then respond or the computer sometimes ends up sending another signal that the device receives.  I've found even a short 5ms being wired to a wait ms timer between each command can often be enough to fix reading queries that used to take several seconds to allowing multiple readings each second.  If you just need data over 5 seconds then you could probably go to 1/4 of a second or 250ms if needed and still have time for around 20 commands.
Depending on your instrument and especially for multi-channel temperature instruments I find you need to check if there is a "scan" mode or just a "measure" mode.  A "scan" mode continually takes readings for all channels and then you simply query the current reading for the selected channel (you can often get the readings from all channels at the same time with one command) while a "measure" mode or command actually invokes the specific measure function of the instrument which often takes a whole lot longer for each reading and often is specific to just one channel and so halts the preparation of readings from all the other channels for transmission (even if the display on the unit itself updates).
A neat trick that is harder to use is to use the timed loops for the measurement sequence.  It is very nice because you can use multiple ones to set up separate code that repeats and yet runs concurrently at different rates and many other things.  One of there features is a option to force the loop to timeout and repeat and sometimes while you won't get a complete set of readings that go-around, the program will still continue for the next series of readings.  You could add a check to see if you got all the readings or not and discard the rest if you didn't and wait for a full set.
Don't know if any of this helps.
-Leif
Message 12 of 15
(1,144 Views)
Thank you so much for ur reply.
I m working on the same n provided info is very helpful..
Manisha
Message 13 of 15
(1,132 Views)
Hey Manisha again,
I m posting one code in which m getting output in highlighting mode but not in run or continuous run mode. Why is it so?
In highlighting mode also I have to press both the buttons (50 ohms, accepts) before I run the VI.
Please help me with this..
Manisha
Message 14 of 15
(1,118 Views)
Manisha,
1. Code which works in execution highlighting mode but not in normal mode almost always has timing problems.  Without your device I cannot test it of course, but I suspect that you may need some delay between the VISA Write and the Bytes at Port in each loop.  Typically you do not both use Bytes at Port and have Enable Terminatio Character set True at the same time. If your device uses a termination character, then let the Read wait for that and get the entire message.  If your device does not send a termination character, then you use Bytes at Port and Read in a loop until you have the complete message.  Either way takes care of the timing issues.
2. Dataflow!  LV is a dataflow language.  This means that any node will only execute when data is availble at its inputs and data will be available at its outputs only after it has completed. If you run the VI with the impedance buttons false, it probably passes through all the loops so fast you do not notice.  I am still not sure what you are trying to do.  You have a large amount of duplicated code.  A Producer/Consumer setup with all the buttons in an Event structure in the Producer loop and one Write and one Read in the Consumer loop can do everything you are trying to do now, and with much less confusion.  The inner case structures in the while loops can be replaced with Decimal Number to String and a Concatenate String outside all the loops.
3. What is the purpose of the 1 iteration for loops? Channel String is empty.  The String Subset ans Multiply in each case could be brought out and only the numeric values would be inside the cases. Less duplicated code; fewer chances for errors.
Lynn
Message 15 of 15
(1,106 Views)
