Can't see port in terminal emulator after controlling it with VISA
I created a LabVIEW VI to control the duty cycle ratios of PWM channels on a FRDM KE02Z microcontroller. The microcontroller, programmed in CodeWarrior, is set up to receive a string from a terminal input and break it down to two parts (channel name and ratio) which are then applied to the PWM. The code works and I tested it with Termite 2.9 and a logic analyzer before controlling via LabVIEW. The problem I've been having, however, is that I have to completely close LabVIEW in order to see the port on Termite again and vice versa.
Previously, I had problems with the VI after I opened anything else besides it, even an almost identical VI, so long as it used the same port. I would get errors and be unable to get my VI to work again unless I restarted LabVIEW. I was able to remedy this by adding a VISA Flush I/O Buffer as per an earlier discussion (http://forums.ni.com/t5/LabVIEW/Timing-issues-with-Serial-Read-Write-can-t-acheive-terminal/m-p/2636... after the configuration of the Serial Port and at least now I can jump between VIs. I am still unable to see the port jumping between LabVIEW and Termite unless I close one; VISA Close and closing the VI aren't enough, I have to close LabVIEW itself. Is it possible to achieve this just within the VI? By using a VISA Flush or VISA Clear at the end (before/after VISA Close) for example? If so, what is the difference/preference between them?
As I mentioned before, the VI is functional but I would like to know what is going on for future considerations. Would appreciate any advice.
Hope to hear from you,
Yusif Nurizade
(4,757 Views)
Accepted by Akello
You haven't wired the VISA Resource Name through the Stop event so it's not closing anything.
(4,753 Views)
Wow.
Hi, my name is Yusif and I make stupid, obvious mistakes.
Thanks for pointing it out to me, I have no idea how I managed to miss that.
Best,
Yusif Nurizade
(4,728 Views)
