Can you set an IP address and then use the ping command for firewire using Windows XP? If so how?
I am trying to test a firewire repeater. My thought was to install two fire wire boards in my test system. Is it possible to set each with a unique IP address, and then use the ping command? If so how do I do this!
Rick.M
Message 1 of 1
(3,125 Views)
