Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can you set an IP address and then use the ping command for firewire using Windows XP? If so how?
Rick.M
Member
11-17-2005
10:24 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am trying to test a firewire repeater. My thought was to install two fire wire boards in my test system. Is it possible to set each with a unique IP address, and then use the ping command? If so how do I do this!
Rick.M
0
Kudos
Message
1
of 1
(3,120 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
