Can you take sofeware written on one computer and use it on another.
We have a problem with the apllication maybe or the gpib. The apllication was working on one computer, but we change out that computer now we can get the program to work. A error message is generated (-107---) and fail to set up the test equipment.
(3,121 Views)
Hi Rickey,
It is hard to determine the problem from this explanation, but have you installed all of the drivers necessary for your program? Is it possible that your program is making assumptions that are not true in your new setup. If you can provide more detail, I can do my best to help you out.
Best Regards,
Aaron K.
Application Engineer
(3,121 Views)
