NI-488.2 Version 2.0 vs 1.70
In my application I am calling ibwait(board,0) to get the current ibsta
value. I need to test the END bit to see if my ibrda() call is finished. I
call ibwait as often as I can in the program (lots of data coming in). I am
using System Monitor on Win98se to watch memory usage. When I use NI-488.2
Version 2.0, I can see Allocated Memory increase very quickly (by 1M every
5 seconds). If I use version 1.7, this does not happen. Any ideas? Is
memory leakage a known issue with the 2.0 driver? I prefer the 2.0 driver
because it seems quicker, but the memory issue will kill any chance of being
able to use it.
(4,087 Views)
Is this the same setup (PC, OS, and application) that you had with the "Multithread problem with ibstop" posting?
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000006F650000&UCATEGORY_0=_26_%24_13_&UCATEGORY_S=0
I just want to make sure I have a good picture of your setup. Also, which GPIB board are you using?
Can you attach an NI Spy capture for when this happens? You can log a capture using the Spy>>Options>>Log to File menu item.
Geneva L.
GPIB/Serial Product Support Engineer
http://www.ni.com/ask
(4,087 Views)
I ran a test using the code attached below which just calls ibwait over and over again. I ran it for an hour and a half and the memory used remained at 4196K according to the Windows 2000 task manager.
At what rate does the memory used increases in your system?.
I'm using NI-488.2 2.0 with Windows 2000 (SP2) and the USB-GPIB-A.
Check out the code and see if there's anything to add or if it does increase memory usage in your system.
DiegoF
(4,087 Views)
In order to run your code I had to reinstall 2.0. I did this over 1.7 (I
did not uninstall 1.7 first). When I did this your example worked fine and
so did my program. So for now I can't even duplicate it. Thanks for your
reply and for your investment of time into my problem.
FYI I'm using Win98se, PCI-GPIB. When it happened memory usage was
increasing at the rate of 1M per 5 seconds.
"DiegoF" wrote in message
news:50650000000500000034CD0000-1042324653000@exchange.ni.com...
> Hi,
> DiegoF
(4,087 Views)
Yes, it's the same. I got around the multithread problem (I hope) by making
sure that all my accesses of the GPIB are done via a single thread. I'm not
happy about this because it's a bit of a 'hack' of the program. I'm using
a PCI-GPIB. Thank you for reply and concern over my previous problem.
My reply to Diego's post explains where I am with my current problem - so I
won't be sending an NI Spy capture. Thanks again.
"Geneva L." wrote in message
news:5065000000050000002FCD0000-1042324653000@exchange.ni.com...
> Hello,
065000000080000
> Regards,
> Geneva L.
> National Instruments
(4,087 Views)
