sample code for OFM20 (OTDR) using LabWindows
OFM20 is made by opto-electronics. C code for LabWindows/CVI or LabView.
(3,802 Views)
We don't have an instrument driver for this device in our instrument library. I would suggest checking the manufacturers site or contacting tech support for programming information. They might have some C solution:
THE OFM20 OPTICAL FIBER MONITOR
If you don't find a ready made driver, you should at least find the programmer's manual of the device. You can use the commands in the manual directly, or develop your own simple instrument driver. You'll find some driver development resources at this site:
http://www.ni.com/devzone/idnet/
Hope this helps. Let see if someone else has any other suggestions or has worked with this device.
DiegoF.
(3,802 Views)
