Cant use GPIB communicate with UF190 prober
Hello
I try to send some GPIB commands according to the reference: UF200 GPIB MANUAL.
such as "J" command:
It needs the carriage return and line feed followed, so I send the command as "J\r\n".
The result is the prober wont take that command. (Its GPIB history log recorded there is a command recieved but cant tell what the command is.)
Also,I tried to read the status bytes from prober, sending with "*STB?" command.
Looks like the prober didn't support this command, because I try to read back the status bytes and it timed out.
I attached the manual file here, is my command format wrong?
(6,921 Views)
Are you positive you are actually sending the control codes and not the characters '\' and 'r'? Your string control/constant has to be set for '\' Code Display.
(6,904 Views)
Yes, I am pretty sure that the \n & \r are commands, not strings.
The command I use is :
sprintf(ts,"J\r\n");
ibwrt(machine_name, ts, strlen(ts));
While I use printf check the ts, its output is only "J" not "J\r\n"
(6,889 Views)
Hi , i also have a question : when i use GPIB to connect with my UF200 PROBE , My NI MAX can not find sucessful about my UF 200 PROBE ,
Could you share with me how do you sucessed to connect your UF190 PROBE WITH GPIB ?
(1,692 Views)
Has anyone here gotten a UF190B to communicate using labview?
(380 Views)
