01-17-2012 08:13 AM
Dear All,
I would like to use an audio box to record with various sampling rates (44.1-192 kHz) and 24-bit I/O using the LabVIEW I have run the Sound Device Input vi and I get a returned bit-depth of 16 bits. Can anyone suggest a way to confim/reconfigure the setup so as to realize the full recording depth of my hardware? I am using LabView version 8.2.
Much thanks,
Daniel
01-19-2012 11:12 AM
Hi Daniel,
Thank you for posting! I'm afraid we might need some further information on the hardware you are tying to use, since it seems you are having little trouble setting it up the way you want. It would be very helpful to know what is what you are conecting to your computer and how (serial, usb, gpib...)
Cheers!
Carlos O
Applications Engineer
11-08-2012 03:33 PM
I have a usb audio interface tascam us-144 and i can't really figure out how to aquire signal and transmit;
it means may be that i need a driver in labview to make it work, if that's the case, i need help.
could you please help me it's urgent for my project !
11-10-2012 05:02 PM
11-13-2012 03:52 PM
it didn't work, it tells me an error on visa driver
11-13-2012 05:42 PM
Can you post the full description of the error or the specific error code?
11-14-2012 04:49 AM
There it is
11-14-2012 11:54 AM
Hello Brahim310,
The error you are seeing is a result of the bcdUSB device descriptor which should be 0x0200 not 0x200.
See this knowledge base article
http://digital.ni.com/public.nsf/allkb/E811055409D5B8778625782900701DFB?OpenDocument
11-14-2012 12:25 PM
I see !
so in this case it can't works, ![]()
is there any solution that can be done to make it work
11-14-2012 01:03 PM
I've been looking into it and I apologize I gave you some misinformation. The error that you are seeing is similar to the link that I sent you however the issue seems to be with one of the other descriptors that your USB device is referencing. Unfortunately, I haven't been able to find documentation as to what can be done to fix these types of issues. You might want to look for possible device drivers made from the device company you are using.
