Capturing FFT waveform from Agilent Oscilloscope and displaying on LabVIEW front panel.
Using LabVIEW I was able to command the function generator to output a signal. I then commanded the oscilloscope to capture the waveform and plot the FFT. I now want to take the FFT waveform displayed on the oscilloscope and duplicated it to display on my front panel vi. How do I go about doing so without using any drivers?
(4,948 Views)
Same way you learned the other commands, by reading the manual. I'm not at all sure why you would not want to use a driver. At least find one and see if the function exists and copy the code. Otherwise, you should ask Keysight. This is not a problem related to LabVIEW.
(4,940 Views)
It isn't necessary to use a driver if you don't want to.
I don't necessarily use a driver.
Even when I use a driver, I always read the programmer's manual.
I want to understand what the driver is doing.
(4,922 Views)
