Center Frequency and Span for Spectrum Analyzer ESA
Hello All,
I am asking one silly question but i tried many things didn't work out so asking you all.
I need to set the spectrum analyzer as follows:
RBW: 10Khz
Sweep:AUto
Span 2400Mhz
Ref Level -40 dBm
Trace 1: View
Trace 2: max Hold
Tarce 3 :min hold
Andt MAIN CENTER freq 65850kHz
But when i run my program all values are getting set ex CENTER FREQ it always sets as 1200Mhz.
I dont know is there any automated adjustment that Center freq always come to appro to half of span????
If anyone can tell me the solution for this...
Thanks so much
Message 1 of 8
(6,170 Views)
Hi pals,
it looks like a problem with you external Hardware. Please contact the manufacturer of your Spectrum Analyzer or use the manual to find out if why your Spectrum Analyzer always change your settings.
Message 2 of 8
(6,147 Views)
Thanks a lot....
i think so that there is any auto calculation happening  so it always cet center freq to app half of center freq when i run the labview program. But when i set manually it does set... So i thought its a problem in code....
Pals
Message 3 of 8
(6,145 Views)
Hi Pals,
even is there a problem with a single VI you using in your program you have to contact the manufacturer because he is accountable for the VIs for his hardware.
Message 4 of 8
(6,141 Views)
Hi Dennis,
Thanks so much.... Surely i will.... initially i thought that some problem in my program only....
Thanks so much....
pals
Message 5 of 8
(6,138 Views)
Hi Pals,
in my opinion the code looks good and workable I don't think there is any problem.
Message 6 of 8
(6,136 Views)
Hi Dennis,
Thanks once again....
pals
Message 7 of 8
(6,134 Views)
Accepted by Sim5
Hi all...
Got the solution the difference between center freq and span is too huge... So its not accepting....
Now i am getting the correct values.... Due to this huge range start freq of spectrum was going below range... That was the problem....
Thanks all....
Message 8 of 8
(6,116 Views)
