Centos7.9 cannot add GPIB-ENET/100
I ran into some problems when using GPIB-ENET/100 in a Linux environment, and I hope to get help.
Background description:
Operating system: centos7.9, 64-bit;
ni-488.2: 17.0;
ni-kal: 17.5;
gpibexplorer can run, and fill in the IP of GPIB-ENET/100 to find the NI hardware. When connecting, it prompts "Device currently not in configuration mode, Press and hold the CFG RESET button on your Ethernet device for three seconds to enter configuration mode". But after I reset the GPIB-ENET/100 as I did, I still get this prompt and I can’t go to the next step.
I can add GPIB-ENET/100 and communicate normally under the MAX of win10。
Attached are screenshots of ni's installation status and screenshots of gpibexplorer
Message 1 of 1
(1,083 Views)
