Wiring diagram humidity sensor HIH 4030 and NI-9201
I measured relative humidity using HIH 4031-003 in collaboration with NI-9201. This sensor has 3 pins, namely (+) supply Voltage 5Volt, Voltage out (to channel 1 on NI-9201), and (-). I have problems with the output measurement results in the form of fluctuating voltage values such as noise. Is the wiring diagram that I made correct?
What is the solution to my problem?
Thank you.
(2,640 Views)
Wiring looks correct, what does the output signal look like?
I think this sensor is sensitive to light from what I saw on a spec sheet, try putting something over to block the light.
-Ak2DM
(2,625 Views)
it, is the datasheet of the sensor, and the graph of the voltage output.
https://www.sparkfun.com/datasheets/Sensors/Weather/SEN-09569-HIH-4030-datasheet.pdf
(2,605 Views)
Try putting a 100Kohm resistor between the OUT and -Ve (Spec sheet shows a minimum load of 80kohm). I am wondering if the 1Mohm input impedance of the 9201 is causing issues.
-AK2DM
(2,585 Views)
I already using 80 kohm, next i will try with 100 kohm. Thank you
(2,572 Views)
