Communication with Smart Tweezer LCR Tester 1707
Hello, this is my first attempt at posting a thread so i just hope this is the correct board.
I have a project where i need to measure the inductance of an inductor with this instrument from RS PRO, and i'm just asking how could i transfer the data i read from it to process it in Labview. Do exist drivers or som procedure to achieve it?
thanks
(3,322 Views)
No instrument drivers in the instrument driver page, but probably it is a simple serial port interface via usb.
I don't know the instrument but if you need advice, you can always ask.
greetings from the Netherlands
(3,299 Views)
The website mentions the Bluetooth model with a USB receiver can be used with LabVIEW - http://www.lcr-reader.com/bluetooth.html
The Smart Tweezers ST5S-BT2 is available in the LCR-Reader Store. Siborg has created two options for the device; one with the receiver stick and the other without.
Please note when purchasing: the receiver stick is needed for computers to receive the data. Some communication software requires the receiver stick, including NI LabView®
The LabVIEW driver is located - http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=25308
(3,296 Views)
Accepted by travisperro
I got help form one of my workmates, and it was that, a UART to USB bridge with 16 bytes where the 5th and 6th contained the useful data
(3,249 Views)
