Compatibility of GPIB32.DLL with Agilent Interfaces
I fully realize this is a NI-sponsored arena but have a question. I have successfully implemented NI GPIB controllers into my software package and am branching out to include other controllers like the Agilent series. A little research has led me to believe I will be making a new library (dll) interface for my development environment. No biggie... I was just wondering if the NI supplied GPIB32.dll is cross-manufacturer compatible before I go down that path.
Has anyone written low level sytems to handle multiple-vendor interfaces in this manner?
(4,049 Views)
They are not the same. If you want to use a single program with GPIB cards from NI and Agilent, you should be using VISA commands in your program and not the lower level GPIB commands (i.e. ibwrt, ibrd). VISA is a cross-platform api.
(4,047 Views)
It's not only cross platform, it is also to a large part interface independent (with the exception of things like opening ports and configuring communication parameters).
So you can write a program that uses GPIB, RS-232 and USB interfaces (for example) that uses the same code for all but the initialization.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(4,021 Views)
