Error -1073807339 During VISA Read
I'm getting Erro -1073807339 whenever I do a VISA Read. I tripple checked my baud rate, made sure device and port are set to the same rate. Increased timeout time, reduced the number of bytes to read to 1 and still no luck. I'm not sure if this has anything to do with my problem but this same VI runs on an older laptop running LabVIEW 7, now I'm using LabVIEW 8 and I get this error. Any suggestions?
Thank you,
miguel23
(3,317 Views)
Hi Miguel,
Can you post a (simple) VI which gives this time-out ?
(3,299 Views)
