Comsoft profibus with DP/PA coupler
I am using Comsoft DF_PROFI2 with P&F Coupler to connect PA device. I am not able to configure the PA device in the configurator. I am getting "Station not Existent". Please help to resolve this issue.
(4,571 Views)
Dear kaush,
please try to use the busparameter settings from following side: http://www.profibus.felser.ch/index.html?dppa_segmentkoppler.htm
Try to create a livelist after switching to online mode.
regards,
Sven
(4,566 Views)
Hello Sven,
Thanks for the reply. I am not to change the master bus parameters. Please see the attached screenshot.
(4,555 Views)
Hello Kaush,
please select in the tab "Profibus" the Profile "user defined". Then you are able to set the bus parameters.
Sven
(4,542 Views)
Hello Sven,
I am able to get my PA device online and see the parameters. I want to know how to get the data into labview. Is there any example or document which i can refer. I am using LV 2009.
(4,503 Views)
Hello Kaush,
This link would give you a complete overview of the Modbus Library for LabVIEW - https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
There is a tutorial on using the Modbus library as well as a demo on creating an I/O server with the DSC module.
Regards
arjun
(4,482 Views)
thank you Arjun,
this was great, and solved my issue.
(942 Views)
