Connect hamamatsu c9525 to labview via USB port/communication error
because it was not clear to me what it was that I had to do.
How would I create a CR constant?
Message 51 of 62
(1,942 Views)
I already went to Visa Read/ byte count input/, changed Display format to hexa and wrote D in the constant box which is CR in Char.
but it still sees it as 13 numeric
what should I write in the byte count in order for Visa read to understand it should stop at CR?
something else:
hammamatsu receives instructions ending in CR
but does not send back 0D (cr), it only sends data without a termination character;
Request: 28.10.2014 17:24:35.22764 (+724.1494 seconds)
46 0D F.
Answer: 28.10.2014 17:24:35.32464 (+0.0970 seconds)
56 65 72 31 2E 36 30 20 43 39 35 32 35 2D 30 33 Ver1.60 C9525-03 FA0015
46 41 30 30 31 35 20 20
Port closed
 Request ended in 0D
Answer ended in 20 which is space
Request: 28.10.2014 17:11:57.19864
52 0D R.
Answer: 28.10.2014 17:11:57.36664 (+0.1680 seconds)
00 00 0A 00 01 00 05 01 01 00 00 00 2D
answer ended in 2D which is - minus
So, if the read is waiting for CR it is not going to receive it.
How do you see this situation?
Message 52 of 62
(1,928 Views)
How do I make a button that, when pressed in the front panel, sends 460D toVisaWrite write buffer and 24 to the Visa REAd Byte count ?
Message 53 of 62
(1,925 Views)
First thing to do is on the VISA Configure Serial Port, right click on the termination character terminal and select Create Constant.
For your main, use an Event Structure. For a value change event of the button, place your VISA code.
Message 54 of 62
(1,921 Views)
I had already done that the instant you told me not to mess with Visa Serial and only work in the main block diagram.
Visa Serial has a constant set to True at its Enable Term.Char. input.
And thank you for telling me about "event structure" too, I am working on it right now.
Message 55 of 62
(1,909 Views)
What function transforms the boolean 1 ,resulted from pressing the "Read value" trigger button in the front panel,
to decimal value 24
which I need to connect to Visa Read Byte count?
I need something that is triggered when receiving boolean 1 and Outputs the decimal 24.
Where do I find that object?
Message 56 of 62
(1,904 Views)
The above question still stands;
meanwhile I solved the 24 decimal input to visa read byte count by placing a constant ~24~ inside the event structure, tying it to the border and tying the border to the visa read byte count.
My first attempt had been unsuccessful because I simply dragged the constant into the event trigger rectangle and it did not work.
Now it does.
But still:
what object is triggered when receiving boolean 1 and Outputs the decimal 24.
Message 57 of 62
(1,899 Views)
I don't understand what you have done. Please attach an image of the block diagram.
Message 58 of 62
(1,893 Views)
The first event in the Event struct. is read info which has the command in the box and returns 24Bytes
the second is Quit/turn off remote which has the command in its box and receives 2 Bytes.
As shown in the picture, they work perfectly.
Now
I need to insert into another event command box a dynamic command such as the voltage regulation:
for that I created this prototype (in picture 2) which takes decimal values coming from the Numeric Control,
didides to 100, splits the quotient and the remainder, transforms them to hexa,concatenates them and adds V in front of the string and CR behind(this is the syntax Hamamatsu understand V value1x100+value 2).
I need to insert this command into an event.
To make it simpler: adjust the value from the knob, then click SET button and only then the value is sent to the event, thus making it simpler.
How do I insert the voltage command into an event structure?
Message 59 of 62
(1,889 Views)
I'm sorry but none of that code is even close to correct. You still have not defined the termination character and the event cases are completely wrong. You need a while loop around the event structure. In the read event, the Boolean needs to be inside the event and you need the VISA Write and Read in there as well. The only code that belongs outside the loop is the configure and close functions.
These mistakes can be solved by taking the numerous free tutorials and by looking at the shipping examples.
Message 60 of 62
(1,885 Views)
