Connect instrument to pc to pilatate with LabVIEW using gpib scheduler
Message 21 of 35
(3,150 Views)
I have done!!! OK!!! I'VE ISTALLED LabVIEW7 and Driver NI-VISA and GPIB USB B driver. With MAX I can see my device, but... how can now controll it with LabVIEW?
Vanny
)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(
Sweet, Beautiful and Young Female Physicist (SBYFP)
(I speak a not very good english, so If U are Italian LabVIEW expert speak in Italian, if U speak in Eglish... please speak easy;) )
My e-mail for personal contact: vanessaricciardi@live.it_NO_SPAM_PLEASE
Message 22 of 35
(3,138 Views)
Vanny
Message 23 of 35
(3,135 Views)
But the icon VISA abc is intermetted and the first line on left to its icon violet have a contorn black that move itself... but What i can do whit this? I don't understand... I desire to set frequency, amplitude, ecc. ecc. What I can do?
Vanny
Message 24 of 35
(3,133 Views)
Turn off the pause mode (click on the pause button on the toolbar) and just let the VI run.
If you want to control other parameters of the instrument, you have to load the appropriate function in the driver. Go to Help and select Show Context Help. The help window will have a description of the VI as you move your mouse over it on the palette.
p.s. The front panel VISA Resource does not look correct. It may be a very old driver and would need to be modified. If you get an error with the initialize function, report back. Too bad you chose LabVIEW 7.1 over 8. That's a decision that I still don't understand.
Message 25 of 35
(3,114 Views)
La persona che ha scritto che il VI ha lasciato un punto di interruzione. Fare questo:
  1. Metti il mouse sul punto rosso.
  2. Fare click sul bottone destro del mouse.
  3. Selezionare "Clear Breakpoint". ("Cancella punto di interruzione")  (picture)
  4. Salvare il VI.
Aprire la "Getting Started" esempio:  (picture)
Altre funzioni sono nel "Configuration", "Action/Status", ecc. tavolozze.
Message Edited by smercurio_fc on 01-14-2010 12:02 PM
Message 26 of 35
(3,112 Views)
mercurio, se nn è un problema, per evitare di avere risposte con molte ore di ritardo... mica puoi contattarmi in pvt?
Vanny
Message 27 of 35
(3,078 Views)
Dennis Knutson I have click on pause and after on play, but the result is showed in the Figure.
I don't understand what is the error.
I have a questions:
1) What is the icon VISA abc?
2) What means \n* CLS\n?
3) What means Visa session at the left?
4) What is the two icons at the right?
5) What means SET in blue?
6) What is DUP VI at the right?
Vanny
Message 28 of 35
(3,076 Views)
he vanny,
as I already mentioned, beginning is quite easy. As a general rule: Please use only RSSMIQ*.vi and RSNRTZ*.vi for open/close instrument session and for remote control!
For the NRT-Z please have a look at the attached screen copies.
Message Edited by juergenstraub on 01-15-2010 10:56 AM
Message 29 of 35
(3,065 Views)
juergenstraubvery thanks, but... where have u find a driver for labview of my Power Meter NRTZ43 of Rohde & Schwartz??? Because I have a driver, but when i put icon of Getting started on desktop compare this message:
"RSNRTZ Application Measure Power.vi
  Virtual Instrument
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\RSNRTZ Reset.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtz.llb\RSNRTZ Reset.vi".
RSNRTZ Config Measurement.vi
  Virtual Instrument
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Write And Read Response.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Write And Read Response.vi".
RSNRTZ Error Query.vi
  Virtual Instrument
RSNRTZ Initialize.vi
  Virtual Instrument
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Utility Default Instrument Setup.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Utility Default Instrument Setup.vi".
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Utility Clean Up Initialize.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Utility Clean Up Initialize.vi".
RSNRTZ Measure.vi
  Virtual Instrument
RSNRTZ Select Forward Measurement Mode.vi
  Virtual Instrument
RSNRTZ Select Reverse Measurement Mode.vi
  Virtual Instrument
    - The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Write And Read Response.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Write And Read Response.vi"."
What's means??? Respond me soon please...
Vanny
Message 30 of 35
(3,048 Views)
