01-14-2010 09:45 AM
01-14-2010 10:50 AM
01-14-2010 10:56 AM
01-14-2010 10:59 AM
01-14-2010 12:00 PM
Turn off the pause mode (click on the pause button on the toolbar) and just let the VI run.
If you want to control other parameters of the instrument, you have to load the appropriate function in the driver. Go to Help and select Show Context Help. The help window will have a description of the VI as you move your mouse over it on the palette.
p.s. The front panel VISA Resource does not look correct. It may be a very old driver and would need to be modified. If you get an error with the initialize function, report back. Too bad you chose LabVIEW 7.1 over 8. That's a decision that I still don't understand.
01-14-2010 12:01 PM - edited 01-14-2010 12:02 PM
La persona che ha scritto che il VI ha lasciato un punto di interruzione. Fare questo:
vanny wrote:
desire to set frequency, amplitude, ecc. ecc. What I can do?
Aprire la "Getting Started" esempio: (picture)
Altre funzioni sono nel "Configuration", "Action/Status", ecc. tavolozze.
01-15-2010 02:57 AM
01-15-2010 03:12 AM
Dennis Knutson I have click on pause and after on play, but the result is showed in the Figure.
I don't understand what is the error.
I have a questions:
1) What is the icon VISA abc?
2) What means \n* CLS\n?
3) What means Visa session at the left?
4) What is the two icons at the right?
5) What means SET in blue?
6) What is DUP VI at the right?
01-15-2010 03:55 AM - edited 01-15-2010 03:56 AM
he vanny,
as I already mentioned, beginning is quite easy. As a general rule: Please use only RSSMIQ*.vi and RSNRTZ*.vi for open/close instrument session and for remote control!
For the NRT-Z please have a look at the attached screen copies.
01-15-2010 09:54 AM
juergenstraubvery thanks, but... where have u find a driver for labview of my Power Meter NRTZ43 of Rohde & Schwartz??? Because I have a driver, but when i put icon of Getting started on desktop compare this message:
"RSNRTZ Application Measure Power.vi
Virtual Instrument
- The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\RSNRTZ Reset.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtz.llb\RSNRTZ Reset.vi".
RSNRTZ Config Measurement.vi
Virtual Instrument
- The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Write And Read Response.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Write And Read Response.vi".
RSNRTZ Error Query.vi
Virtual Instrument
RSNRTZ Initialize.vi
Virtual Instrument
- The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Utility Default Instrument Setup.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Utility Default Instrument Setup.vi".
- The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Utility Clean Up Initialize.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Utility Clean Up Initialize.vi".
RSNRTZ Measure.vi
Virtual Instrument
RSNRTZ Select Forward Measurement Mode.vi
Virtual Instrument
RSNRTZ Select Reverse Measurement Mode.vi
Virtual Instrument
- The subVI expected to be at "C:\work\RSD\drivers\rsnrtz\lv6_vi\rsnrtzu\RSNRTZ Write And Read Response.vi" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 7.1\instr.lib\rsnrtz\rsnrtzu.llb\RSNRTZ Write And Read Response.vi"."
What's means??? Respond me soon please...
