05-11-2010 04:17 AM
I'm currently trying to use 9871 in two wires mode.
I've compiled a little FPGA bitfile that just writes periodically a character on Port 1 of my module.
the port is configured as the following : 9600 bps, two wires auto, no parity 1 stop bit.
To receive this char i use a RS485=RS232 converter that works fine with some instruments working on rs485. This converter has two line inputs : + and - .
My question is the following, which are the 9871 lines to connect to this pin when it is configured in two wire modes ?
I didn't find any KB on this !!!!
I guess it's the RX+ and RX- lines but I'm not sure.
do someone can confirm it to me ?
Solved! Go to Solution.
05-12-2010 05:30 AM
You need connect TX+ RX+ & TX - RX-
Maybe this document could help :
http://decibel.ni.com/content/docs/DOC-4169
05-17-2010 01:52 AM
Hello
thanks a lot for this info, I tried it just after sending the post and it works fine.
At the beginning I was guessing that the connection was done internally by the module as in a lot of RS485 interfaces from ohter companies.
Thanks for your quick response.
