Connecting A CompactRIO Controller To A Wireless Network
I got a CompactRIO connected to a wireless network. So far the CopactRIO is available over one IP adress and the communication is working well.
Anyhow I would like to avoid making more than one computer able to be connected to the CopmactRIO at the same time. Like this I want to avoid the case that two programs are compiled on the FPGA at the same time. Any ideas how to do this?
(3,993 Views)
Svenja,
This should be documented somewhere in RIO, but the way you can prevent computers from downloading FPGA VIs to the CompactRIO if using NI-RIO 2.1.2 or earlier, is by going in MAX to the controller>>Software>>NI-VISA tree item, selecting the VISA Options page, browsing to VISA Server>>Security and enabling/disabling access to computer as you see it fit.
If you are running into this problem because you trigger the compile of the FPGA VI through the VI's run arrow, I suggest you use the alternative way for compiling an FPGA VI which is to browse to it in the LabVIEW Project, right-click and select Compile. If you do this, the FPGA VI will not be automatically downloaded after is compiled.
(TIP) Something that I think not many people know about but it is very useful, is the "Target-Specific Properties" right-click option on FPGA VIs. This option gives you information about whether the VI needs to be recompiled and a bit more information such as when was the last time it was compiled and that compile results (like FPGA utilization). I believe this feature was added with LV FPGA 8.2.
Hope this helps.
JMota
(3,976 Views)
