Connecting a pH sensor to an A/D converter then to computer via LPT1
I am new to Labview and am having some problems getting data from my sensor. I have my sensor connected to an a/d converter which is connected to my computer. I am now trying to build a VI to read the pH data from my sensor, however I have not been able to do this...perhaps mostly due to my inexperience with labview. Could someone please advice and help? thank you very much.
(3,267 Views)
You can do a search for parallel port at www.ni.com. You'll probably find some interesting articles and example programs.
Here's the link to a tutorial on using the parallel port in LabVIEW:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/72C6FC6CE4AD4D1386256B1800794596?opendocument
Also, check the LabVIEW support site: http://www.ni.com/support/
Hope this helps.
DiegoF
National Instruments.
(3,267 Views)
