Connecting an NI data aquisition card to accelerometers
I got an NI PCI-6010 card which I have set in the computer and I want to connect the connecting block that came with it ( https://www.ni.com/en-us/support/model.cb-37f-lp.html ) to a signal conditioning box and power supply for three accelerometers. I have 3 wires, one for each accelerometer and an earthed cable. I want to know which holes I should connect these wires to on the connector box?
Cheers,
Sam
(3,473 Views)
Hi Sam,
You can access the pinouts for your device from the NI-DAQmx Device Terminals help file that is installed with DAQmx.  A quick way to access this file with the exact pinout you need is from Measurement and Automation Explorer (MAX).  In MAX under Devices and Interfaces, right-click on your device and select Device Pinouts.  This will open the help document, as well as go directly to the pinout diagrams for that particular device.
Also page 3 of the manual provides some further information on connecting the signals.https://www.ni.com/docs/en-US/bundle/371538a/resource/371538a.pdf
I hope this information helps.
Kind regards,
Prashant M
NI UK & Ireland
Message Edited by Prashant M on 08-28-2009 04:29 AM
(3,420 Views)
