Problem with Serial Transmission to MCB2300 (3-20 Errors every 100 transmitted Values)
I try to trasnmit a Sawtooth to a MCB2300 via Serial (UART). Every sawtooth has 100 values and after transmission 3-20 values on the MCB2300 are allways wrong.
I work with 9600bps, and the samplerate of the Sawtooth is 25hz.
The attached example Files are for LabVIEW 8.6
bye & thanks
amin
(3,812 Views)
It seems I did something wrong with the semaphores in the MCB2300 VI.
If I leave them out, I get allways just 4-5 Errors.
bye
amin
(3,804 Views)
One more Version with Semaphores.
Now I have "just 2-3 Errors, but still no 100% working version.
 bye
amin
(3,800 Views)
Accepted by topic author aminat
Now I made a working Version.
So the Problem is solved.
bye
amin
(3,785 Views)
