Control box between labview and tektronix oscilloscope and ISCO syringe pump
I need to order an interface box between my computer and several machines, these machines include tektronix oscilloscope, Tyledyne syringe pumps and thermocouple. please give advices on which one I shall order from NI.com
Thank you!
(5,301 Views)
So you posted in the correct board but did not provide any of the necessary details I asked for. Why not?
http://forums.ni.com/t5/Multifunction-DAQ/DAQ-between-labview-and-tektronix-oscilloscope-and-ISCO-sy...
(5,299 Views)
For the physical connections, it is RS-232 to the pumps, Etherbet with oscilloscope. There is no thermcouple yet, we only need to pre-set some ports.
(5,268 Views)
So as long as you have a serial port and ethernet connection on your computer, you are good to go with those.
For the thermocouple, you may need to buy a DAQ board.  Something like the USB-6000 should work for you.
(5,265 Views)
Google 'USB to Serial' if you need multiple ports. NI has a product line as well. https://www.ni.com/en-us/shop/category/gpib-serial-and-ethernet.html
Besides the 6000 and the entire line of multifunction DAQ boards, there is the cDAQ modules: https://www.ni.com/en/shop/compactdaq/compactdaq-modules.html
You really need to provide more details in order to be more specific. Number of channels, desired resolution, etc.
(5,259 Views)
