Unexpected Error in NI MAX
i sometimes receive these errors in MAX (Measurement and Automation Explorer):
The niGPIBsys.dll plug-in caused an exception in the CmxSysExpertManager::InitializeExpert function in the NIMax process.
See these files for details:
C:\ProgramData\National Instruments\MAX\Logs\20130715_132347-NIMax-00001B7C.log
C:\ProgramData\National Instruments\MAX\Logs\20130715_132347-NIMax-00001B7C.dmp
OR
The niGPIBsys.dll plug-in caused an exception in the CmxSysExpertManager::FinalizeExpert function in the NIMax process.
C:\ProgramData\National Instruments\MAX\Logs\20130718_105523-NIMax-000017A4.log
C:\ProgramData\National Instruments\MAX\Logs\20130718_105523-NIMax-000017A4.dmp
After PC restart this works fine and I dont get error messages in MAX.
I use Labview 2011 SP1 and Windows 7.
Hardware from NI: PCIe-6259
The folder "ProgramData" does not exist, so I cannot find the files listed above.
This is a new installation of LabView 2011 on a new computer, but settings in MAX are imported from old PC and the PCIe-6259 card was also taken from the old PC.
I installed all critical updates via the NI update service for NI 488.2, NI serial etc., but it did not help. I also removed entire MAX database and imported in again, but no progress.
What should I do? Thank you for any ideas.
Petr
Message 1 of 8
(7,430 Views)
Hi Petrm,
what kind of configuration did you take from older computer? Can you try not to take this old configuration and make it on the current computer after resetting MAX database via Tools > Reset Configuration Data? This can be source of these problems. Also make sure that you have newest drivers (DAQmx) including the MAX.
By the way, of course, that ProgramData folder exists, but it is hidden. You can enable to see these hidden folders but even without it, ProgramData folder is accessible, e.g. directly write a path to the Explorer window.
Martin
Message 2 of 8
(7,399 Views)
I have found that the ProgramData folder is hidden Smiley Happy
Then I resetted the MAX database and imported tasks and channels that are related only to PCIe-6259 card. Some task on old PC were related to an USB DAQ cards, which are no longer connected to new PC.
Now it looks like it works, no error messages yet.
When I connect an USB DAQ card to the new PC, I guess I must create new tasks and do not import anything from old PC.
Petr
Message 3 of 8
(7,391 Views)
Hi Petrm,
yes, do not import the tasks, try to create them instead if possible (I do not know how extensive settings you have there).
Martin
Message 4 of 8
(7,382 Views)
@AECmartin wrote:
Hi Petrm,
Martin
Better yet,  Make them "project" Tasks and keep them out of "XML- Hell" (MAX)
Message 5 of 8
(7,357 Views)
I have resetted the MAX database and created only 3 tasks manually in MAX, but the next day after starting the computer I got the same error with GPIB after starting MAX.
How do I create project tasks? I am new to LabView, I use some VIs created by my colleague, but I would like to learn more.
Thank you.
Message 6 of 8
(7,329 Views)
Hi Petrm,
In this case will be better to create task using Express VI and generate DAQmx code. In the https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1AFCAY&l=en-US you can find description how to do that. Once you have task created using LabVIEW code, there is no problem with MAX (at least you can easilly reset MAX database, import PCI card and continue after MAX crash). And it is also good that you will configure task well readable and you can compare generated code with configuration made. For beginning it is very powerful learning tool.
Even better solution is to create your DAQmx tasks manually or use examples (and modify them for your needs) from Help > Find Examples, there select Hardware Input and Output > DAQmx > Analog Input (or type of the task you want to use). Basically, the task consists of 1. create task, 2. configure task (timing, trigger), 3. run task (acquire or generate data) and 4. clear task. There is nice Getting Started on https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page... , mainly Basic Programming with NI-DAQmx section can be useful for finding way how to do that.
Martin
Message 7 of 8
(7,305 Views)
Hello I made a reset configuration Data but now have the following:
The AsstntUI.mxx plug-in caused an exception in the CmxProviderWrapper::GetBindingClasses function in the NIMax process.
C:\ProgramData\National Instruments\MAX\Logs\20140619_091614-NIMax-000010E8.log
C:\ProgramData\National Instruments\MAX\Logs\20140619_091614-NIMax-000010E8.dmp
Do you know why happened this?
Thanks.
Message 8 of 8
(6,588 Views)
